How to Set Up the nami Alarm System
How to Install the nami Alarm System
This guide walks you through setting up your nami Alarm 15 kit with your Alarm.com account. The nami system uses Wi-Fi sensing technology — no traditional panel required. When installed, it works just like a standard security system: arming, disarming, detecting intrusion, and sounding an alarm when needed.
What’s in the Box
The nami Alarm 15 kit includes:
  • 1 nami Alarm Pod (the hub and siren) + power adapter
  • 1 nami keypad
  • 1 nami door sensor
  • 1 nami SensePlug (Wi-Fi motion sensors that plug into outlets)
  • 1 nami PIR motion sensor
Before You Start
Make sure you have the following ready:
  • The Alarm.com Customer app installed on your phone (iOS 16+ or Android 9+)
  • Bluetooth turned on on your phone
  • Your Alarm.com account login credentials
Step 1: Open the Alarm.com App and Start Device Enrollment
  1. Log in to the Alarm.com Customer app.
  2. On the main home page tap the GET STARTED button.
  3. Begin the nami enrollment flow and continue through the introductory screens.
  4. Tap the Kit you will be adding
If you have already added devices and want to add more:
  1. From the bottom navigation bar, tap More
  2. Tap on Add Device
  3. Tap nami and follow the steps
Step 2: Create or Select an Area
An “Area” is the zone your sensors will cover (similar to a room or floor).
  1. Select an existing area or tap to create a new one.
  2. If creating a new area, give it a descriptive name like First Floor or Living Room, then tap Create Area.
Note: Each area supports a maximum of 4 activity sensors (Alarm Pod + SensePlugs combined).
Step 3: Set Up the Alarm Pod
The Alarm Pod is the heart of the system — it acts as the siren and main hub.
  1. When prompted, tap Next on the Add Alarm Pod screen to open the QR code scanner.
  2. Scan the QR code on the back of the Alarm Pod (behind the plastic cover).
  3. After scanning, plug the Alarm Pod into power. It should pulse dark blue to indicate it is in pairing mode.
  4. Enter a name for the Alarm Pod when prompted.
  5. Once Bluetooth pairing is complete, select your Wi-Fi network from the list and enter the password.
The app will display a progress screen while the device connects. Once connected, tap Next to continue.
Step 4: Set Up your SensePlug device
SensePlugs are Wi-Fi motion sensors that plug into standard wall outlets.
For each SensePlug being added:
  1. Review the placement tips on screen, then scan the QR code on the unpowered SensePlug.
  2. Plug the SensePlug into a wall outlet. It should pulse dark blue.
  3. Enter a name for the SensePlug when prompted.
  4. The app will confirm successful enrollment and show kit progress.
Repeat these steps for the second SensePlug.
Placement tip: For best performance, place SensePlugs within 10 to 30 feet of each other and the Alarm Pod.
Step 5: Set Up the PIR Motion Sensor
  1. Follow the on-screen placement tips for the PIR Motion Sensor.
  2. Follow the steps on screen to remove the battery tab and scan the QR code.
  3. After the device enrolls, follow the in-app instructions to physically install the PIR Motion Sensor.
Step 6: Set Up the Door Sensor
  1. Follow the on-screen placement tips for the door sensor.
  2. Scan the QR code on the door sensor.
  3. While the sensor is enrolling, press the top button once (a short, firm press — not a long press). The sensor should pulse white while in enrollment mode.
    Note: The LED may be faint and harder to see in bright environments.
  4. After it enrolls, follow the in-app instructions to physically install the sensor on your door.
Step 7: Set Up the Keypad
  1. Follow the on-screen placement tips for the keypad.
  2. Scan the QR code on the keypad.
  3. While the keypad is enrolling, press the [0] button once.
  4. After enrolling, follow the on-screen instructions to install the keypad, then tap Complete Installation.
  5. Follow the prompts to create a PIN for the keypad.
Step 8: Learn Your Security Modes
After installation, the app will walk you through the available security modes. You can control these from the keypad or the Alarm.com app.
Mode What It Does
Arm (Away) Triggers an alarm if the door opens OR motion is detected
Arm (Stay) Triggers an alarm if the door opens; motion inside does NOT trigger the alarm
Disarm No alarms triggered; motion is still monitored
Panic Alarm Immediately triggers an alarm — keypad only (hold SOS button for 2 seconds)
Using the keypad:
  • To Arm (Away): Enter your PIN, then press the Arm (Away) button (upper right)
  • To Arm (Stay): Enter your PIN, then press the Arm (Stay) button (upper center)
  • To Disarm: Enter your PIN, then press the Disarm button (upper left)
  • To trigger a Panic Alarm: Press and hold the SOS button for 2 seconds
Step 9: Test Your System
The app will prompt you to run a system test. It is highly recommended to complete this.
  1. Tap Start Test.
  2. Test the siren: Tap Sound Siren — you should hear it sound. Tap Next.
  3. Test the PIR Motion Sensor: Leave the room monitored by the PIR Motion sensor for 30 seconds. Then, re-enter and walk around. Check the app for a Motion Status Update
  4. Test the door sensor: Open the door where the sensor is installed and confirm the door icon in the app changes to show it is open. Tap Next.
  5. Test the Wi-Fi Motion Sensing: Walk around the room where your SensePlugs and Alarm Pod are installed. Confirm the motion graph in the app changes to reflect your movement.
  6. Tap Complete Test, then Done.
To set the entry and exit delays using the Alarm.com app:
  1. Log in to the Alarm.com app.
  2. Tap Security System to open the Security System page.
  3. Tap the gear icon to open the Security System Settings page.
  4. Tap Entry & exit delays.
  5. Use the dropdown menus to select the desired entry and exit delays.
  6. Tap Save.
Questions?
If you run into any issues during setup, feel free to post in this forum or send us a PM and we will be happy to help!
