How to remove sensors from IQ4?
Is there a way to remove sensors from the system?
I have a new one, right out of the box, but most of the sensors paired are either completely non-functional, or throwing tamper errors. I’m trying to get rid of these so I can at least get some basic functionality.
It looks like settings code 1111 got me into installer mode. It was pretty easy after that.
Not positive but I think the root cause may have been that the QR scanned sensors had the source set wrong. Now I see I could have changed it without removing them, but oh well. Re-added with source as s-line and all seems to be working now.
If anyone else if curious, here’s how you do it.
  1. Swipe down from the top and press settings
  2. Press advanced settings
  3. Enter installer code (default 1111) or dealer code (default 2222)
  4. Go to Installation > Devices > Security Sensors > Delete Sensor
  5. Select the ones you want to delete
  6. Press Delete
A wallkthrough for sensor programming, along with how to find where to delete sensors can be found in the below guide
I would delete and re-add any sensors behaving erratically as a first step. Learn them in manually via panel programming.
