How to program an RE219 Flood/Temp Sensor
RE219 Flood Sensor
The RE219 has three functions, but each function has its own programming, so the RE219 will use up 3 wireless sensor zones.
Flood:
Sensor Type: (08) 24 Hour Auxiliary
Equipment Type: (08) Water
Equipment Code: (0556) exisiting flood/temp sensor
Serial Number: Press “shift,” then “learn,” then tamper sensor by removing cover.
Equipment Age: New
Loop: (2) (Flood)
Dialer Delay: Disabled
Sensor Name: Insert vocab using 2GIG codes found here
Reports: Enabled
Supervision: Enabled
Chime: (desired chime type)
Freeze:
Equipment Type: (06) Freeze
Equipment Age: New
Loop: (3) (Freeze)
Reports: Enabled
High temperature:
Equipment Type: (10) Temperature
Equipment Code: (0556) existing flood/temp sensor
Equipment Age: New
Loop: (1) (Overheat)
Reports: Enabled
