2GIG PIR Motion Detectors
Sensor Type: Interior Follower
Equipment Type: (2) Motion
Equipment Code: (0869) PIR1-345 PIR with Pet Immunity
Serial Number: Click “Shift” then click “Learn”, activate the sensor by moving the sensor, or removing the back plate. Verify the serial number is correct.
Equipment Age: New
Loop Number: (1)
Dialer Delay: Disabled (defaults to “Enabled”)
Sensor Voice Descriptor: Insert vocab using 2GIG codes found here
Reports: Enabled
Supervised: Enabled
Chime: Disabled (defaults to this selection)
