CO3-345 Carbon Monoxide Detector
Sensor Type: 24 Hour Carbon Monoxide
Equipment Code: (1026) CO3-345 2GIG CO Detector
Serial Number: Press “shift,” then “learn,” then tamper the detector by removing the back plate. Verify serial number.
Equipment Age: New
Loop Number: (1)
Voice Descriptor: Insert vocab using 2GIG codes found here
Reports: Enabled
Supervision: Enabled
Chime: (desired chime effect)
