I’m not sure which type of z wave light switch i have and the wizard can’t seem to detect it
Generally you’ll want to try to identify the model number of your devices to have the best understanding of how they work, and have access to correct documentation.
If you are having trouble with adding a device through the Wizard, you could also try to add it locally.
Settings > Advanced Settings > Installer Code > Installation > Devices > Z-wave Devices. Add Device.
While the panel is listening for a device to pair, double tap the light switch.
If it doesn’t work, you may need to clear the device first. This is found in the same menu. Clear Device, then when the panel is listening, double tap the light switch.
Then try adding again.
