An Alarm.com feature I personally enjoy is the enterprise feature. This allows you to link your security and automation alarm systems, and if you’d like use one log in for multiple systems. And its easy to set up.
Go to suretyDIY.com/alarm (or suretyCAM.com/alarm) and enter the alarm.com log in and password for the system you would like to use as your primary log in.
Towards the top of the page, you will see tabs. Click on the last tab, “More”. This will show a drop down, from which you will click, “Profile”.
This will take you to a page with a second horizontal list of click-able options, immediately under the tabs. The last item, furthest to the right, is “Multi-System Access”. Click that option.
From here you can control linkage of your alarm.com powered accounts. At the bottom of the page, it will say, "Add a system to ". Under this, enter the log in and the password of the system you would like to add a link to. Then hit, “Submit”. It will give you the option of eliminating the separate log in if you’d like. If you were to choose to separate the security alarm and automation systems later, you would return to this page and remove accounts via the “'s Systems” section. You can also alter which system is the default system displayed upon log in here.
