Alarm.com offers irrigation management with Hunter Hydrawise Wi-Fi Irrigation controllers. You can run the system, view key zoning and schedule information, and use advanced settings like rain delay to prevent water waste and ensure proper watering for your property from the Alarm.com mobile app.
Available Features
- View watering zones and existing schedules from the Alarm.com mobile app
- Manually start irrigation on selected zones and configure run time
- Setup a rain delay in the event of inclement weather to prevent over watering
- Toggle on Standby Mode to skip all scheduled watering times and manually control the system
- Creating and editing irrigation schedules and forecast data are available in the Hydrawise app
Requirements
- A compatible Hydrawise Controller (i.e., HCC, HPC, X2, or Pro-HC)
- iOS app version 5.9.4+ or Android app version 5.7.4+
- Hydrawise app with a account login
- Irrigation Control service package add-on
- Included with Surety Home and Surety Complete service plans
Before Integrating
Install the Hydrawise controller
Only the HCC, HPC, X2, and Pro-HC controllers are compatible with this integration. Refer to manufacturer-provided installation instructions to complete.
Create the Hydrawise customer account
The Hydrawise controller needs to be connected to the local Wi-Fi network. Download the Hydrawise app to create an account before connecting to Alarm.com.
Add the Hunter Hydrawise Controller to your Alarm.com account
The Hunter Hydrawise Controller can be added to the Alarm.com account using the mobile app.
To add the Hunter Hydrawise Controller to the customer’s Alarm.com account:
- Log in to the Alrm.com mobile app.
- Tap Irrigation.
- Tap Connect Irrigation.
- Select Hydrawise.
- Enter your Hunter Hydrawise app credentials, then tap to grant permission if asked.
- The Irrigation card on the Home screen will automatically refresh after authorization is complete.
