Tap Add Device. If you do not see the Add Device option, please use the Ethernet mode instructions below to complete your installation.
Tap Video Camera.
Tap VC827P.
Follow the on-screen instructions.
Pairing via Ethernet
Complete these steps prior to installing the camera in its final location.
Connect the camera to the router using an Ethernet cable.
If the Ethernet connection does not provide power, connect the camera to the optional AC power adapter (sold separately) and plug the adapter into a non-switched outlet.
Wait 2 minutes for the camera to boot up and connect to the Internet. The LED will be solid green when this process is complete.
Add the device to the account by using a web browser and entering the following web address: www.alarm.com/addcamera.
Select the camera from the video device list or enter its MAC address to begin adding the camera. The camera’s MAC address is located on the bottom of the device or on the packaging.
Follow the on-screen instructions to finish adding the camera.
You can now power down the camera and install it in its final location using the included hardware. You may configure camera settings from the Alarm.com website
If you have issues connecting the camera to the account, power cycle the camera and try again.
If issues persist, reset the camera to factory defaults. Press and hold until the LED is flashing Green and Red (about 15 seconds), then release the button. The camera will reboot with factory defaults.
Note: If the camera was previously installed to a different Alarm.com account, it will need to be deleted before it can be installed again.
