I have a gas fireplace with a wall switch and powered light switch for lights beside it. The fireplace switch is a two wire setup aeotec micro switch will not work. How is the best way to get the fireplace to be able to switch on with my cell phone with zwave.
One option I’m thinking of is using a zwave thermostat and wire the fireplace to the thermostat.
Saw you post on 2gigforum. Hope you didnt go with the Mikes suggestion… he was clueless. That Linear zwave switch requires AC.
Here is how I would do it:
Plug in fireplace to zwave appliance module, or go to lowes and get a GE zwave outlet. Now your fireplace is zwave controllable.
If you want to make the non powered wall switch work, wire it directly to a DW10 in wall , and create an empower rule to tie it to the zwave module
Non powered wall switch to DW10 programming:
Hit logo at bottom right of screen
Enter installer code
System configuration
Right arrow to blank sensor location
Down arrow
(23) no response
Down arrow
(1) contact
Down arrow
(0862) dw10
Down arrow
Learn serial (or hit shift then learn)
Pull magnet away from switch to get serial programmed
Down arrow
(0) new equip
Down arrow
Loop (1) 1
Down arrow
(0) disable dialer delay
Down arrow
Voice descriptor
Down arrow
(1) report enabled
Down arrow
(1) supervised enabled
Down arrow
(00) disabled no chimes/voice
Skip
End
Exit
You will want to verify what it is you are switching. Test the circuit for power, (if it controls and ignition source, or if it controls an actuator or valve for gas flow.)
If there is a receptacle nearby or you are ok running a low-voltage power wire, the Mimolite I linked above would likely work.
I do not know of a simple battery operated Zwave relay.
How does the fireplace ignite? Is there a pilot beneath?
Would have been a whole lot easier (safer) if you had an electric fireplace. I dunno if you want to zwave automate a gas valve… if that pilot goes out… house fills with gas…
yes. Pilot light is on when the switch is flipped. I don’t think the switch will light the fireplace if pilot is not on. I don’t think I have tried it though.
Ok looking at the manual online the fireplace has a millivolt switch. 175-500 millivolts
The gas has a flame checker that will shut off gas if pilot goes out. Otherwise the pilot going out would be a problem with manual or automated operations.
The manual mentions option thermostat. Could I use a zwave thermostat? Or does the thermostat need power?
Gas will not work if pilot is not engaged manually with on off switch
Keep in mind the CT100 will eat through batteries fairly quickly if it is not provided 24VAC power.
I see them typically last a few months, but it will depend on usage.
You could always use a 24VAC plug in transformer to power the thermostat.
This all depends on your intended use case for the automation. Are you looking to create rules like “When a door opens, kick on the fireplace” or “At 9PM, kick on the fireplace?”
A thermostat would not give you the immediate responsiveness of a switch, but it wouldn’t be far off. The app would not be tailored to that function either. But I do not know a reason why that wouldn’t work at the moment. You’d get more functionality out of it too, being able to automatically kick it on (for safety only when home) when the temp drops.
