How to Enroll an Image Sensor into the GC3
Verify XCVR3 installation
Verify the XCVR3 is connected properly to the control panel terminal blocks.
  • Red – Smoke+
  • Black – Common (GND)
  • Green – RX
  • White – TX
For more information on how to install the XCVR3, please reference the XCVR3 installation instructions included with the XCVR3.
Register module and test
Power up the panel and initiate a cell phone test to ensure the communication module is properly installed and communicating with Alarm.com.
Enroll Image Sensor using panel
  1. From the home screen, tap System Settings.
  2. Enter the installer code.
  3. Tap Installer Toolbox .
  4. Tap System Configuration .
  5. Tap Wireless Zones .
  6. Tap to select an unused zone.
  7. For the Sensor type , tap to enter a sensor type.
  • Recommended sensor types are:
    • 04- Interior Follower
    • 10- Interior w/ Delay
    • 23- No Response Type
  1. For Equipment type , tap to select (2) Motion.
  2. For Equipment code , tap to select 9999 Alarm.com Image Sensor.
  3. For Image Sensor ID, tap Learn to put the panel into learn mode.
  4. Power up the Image Sensor by inserting the batteries. Use a paper clip to hold the sensor’s reset button until the LED flashes rapidly for at least two seconds. It will take at least 10 seconds for this to occur. The reset button must be held for at least a full 10 seconds.
Note : A one second fast blink may occur during the reset attempt. This signals that the sensor is not enrolled in a network.
  1. For Equipment age , tap to select the equipment age (i.e., New or Existing ).
  2. For Transmission delay, tap to select enabled or disabled .
  3. For Voice descriptor, tap to edit the voice descriptor if desired.
  4. For Sensor reports , tap to select enabled or disabled . (Enabled is recommended)
  5. For Sensor supervised , tap to select enabled or disabled . (Enabled is recommended)
  6. For Sensor chime , tap to select enabled or disabled .
  7. Continue to edit next sensor or tap Return to System Configuration and tap Save to save the changes and exit.
  8. Perform a cell phone test to verify that the updated equipment list is sent to Alarm.com.
The sensor is now learned into the panel. After enrollment, be sure to keep the sensor and panel powered so the sensor can complete an initialization process with Alarm.com. This process will take several minutes. Images cannot be captured until initialization is complete.
