How to disable Freeze Alarm on detector
Can you let me know process to disable freeze sensor on a fire/smoke/freeze detector? I have tried to get into the programming section (installer mode) and cant seeem to edit the section…
To disable the freeze detector function you would find the zone programmed for that sensor ID using Loop 3 — then mark it as “unused” in its first programming question.
