We just plugged in our new panel and it started right up without going through a setup mode. The time is showing as ET and we cannot figure out how to change it.
The time on the alarm panel is set and maintained automatically through its connection to Alarm.com once it is connected. The time will be based on your system location. It should not be adjusted manually.
Thanks Jason,
We were able to figure this out once we realized we hadn’t set up the system completely yet - duh ![]()
