What’s the version of the SEM that’s on the box/unit? If it has a firmware version listed post that too.
You don’t have a telephone line connected to the Vista, correct?
I have two troubleshooting steps for you to try
According to the documentation, older firmware versions of the SEM are not compatible with voice talking keypads (SEM needs to be on firmware 1.60+ for compatibility). I don’t think the 6270 is a talking keypad but it’s similar to the current talking touchscreen keypads which also use an AUI address.
I don’t have any affiliation with Surety so I can’t check which firmware version your SEM is running from the dealer portal.
I recommend powering down your Vista panel and SEM, disconnecting the 6270 and powering the system back up.
If that doesn’t work. Do a manual master code sync (with the 6270 disconnected).
I recommend deleting all user codes from the system except for the master code. Also, verify you don’t have any codes assigned in the 6270 (newer touchscreens are capable of this, but I’m not sure about the 6270).
The alarm.com documentation recommends changing the master code from the alarm.com app or website. If that doesn’t work, change it locally via the keypad.
According to the documentation, if the master code sync does not work via the website, they want you to change the master code to 1234.
Enter your installer code and press 8, followed by 02, then enter 1234. If that worked the keypad should beep. Wait a minute and verify the master code works. Then test the arming/disarming from the app.
You can also change the master code by entering the current master code + 8 + 02 + new master code + new master code again.
I’m also assuming you have an alpha keypad like the 6160 or similar. If you have a 6160V or talking keypad let me know, because if the SEM is on an older firmware version, it’s not compatible.
I’m not sure what kind of backend access you get with Surety, but if you can update the firmware on the SEM, I recommend doing so. If not, you should request they update it when they’re available during the week.
