Hi,
I have a friend I would like to switch over to Surety monitoring. Can you tell me if the Honeywell Lynx L5100 is ADC compatibility? He currently has ADT monitoring on that panel.
Thanks,
David
Hi,
Thanks,
David
The Lynx is not Alarm.com compatible. His best bet for Alarm.com would be to get a Qolsys IQ Panel 2+ that supports Honeywell wireless sensors or, if he wants lowest possible cost, he might be able to find a used 2GIG GC2 for less. Although he would still need a 4G LTE module for it.
The GC3e would also be compatible with the Honeywell sensors also, correct? Would he be able to use his Honeywell cameras and other sensors as well?
Besides the Qolsys and 2GIG panels, which would you recommend for him?
Thanks!
-David
Yes, the GC3 would also work with Honeywell sensors. He would not be able to use Honeywell cameras with Alarm.com. Of all the Alarm.com compatible panels that support Honeywell sensors, I recommend the Qolsys IQ2+ 345MHz.
