Hi. Are there any good YouTube (or other) videos demonstrating the ENROLL Walk Test and LED Walk Test Modes on the Honeywell 5898 motion sensor? I’ve just installed a 5898 (to workaround pet-induced false alarms on previous PIR motion sensor), and I’m having trouble interpreting the 5898 LED output during these test – it doesn’t seem to match what the instructions say it should do.
The instructions give the following descriptions for LED behavior in Enroll and Walk test modes:
Red ON for 3 seconds = Loop 1 / Low Sensitivity Alarm [Default] Red Blinks rapidly for 3 seconds = Loop 2 / High Sensitivity Alarm Yellow ON for 2 seconds = Microwave event detected Green ON for 2 seconds = PIR event detected Red Flickers rapidly for 3 seconds = Walk test period ended or the flashlight sequence toggled the Loop / Sensitivity and LED indication
ENROLL Walk Test Mode (to enroll or walk test the sensor): This mode is active for 10 minutes and begins either after power up or the sensor cover is opened and closed. When faulted in this mode, the sensor transmits alarm signals to the panel for the selected loop only, and the LED flashes the relative loop indication.
LED Walk Test Mode (to walk test the detection pattern): This mode is active for 10 minutes and is activated using the flashlight feature after Enroll Walk Test mode expires. In this mode, the sensor transmits both loop alarms as they occur, mimicking normal operation. The LED, however, only indicates the selected loop when it is alarmed, allowing a walk test of each loop/sensitivity setting.
So based on the above descriptions, I’m expecting to see:
But instead, what I’m seeing is that the LED lights up with several colors (green/yellow/red) in quick succession, like all three colors within a second. Sometimes two colors, sometimes all three. That behavior doesn’t match any of the descriptions in the instructions that I’ve found. Even if I were somehow in LED Walk test mode (which I shouldn’t be, since I haven’t used the flashlight feature to switch into it), I should be seeing each color for at least 2 or 3 seconds.
The unit itself seems to be working OK, based on the fact that it did light up in response to movement during the walk test, and based on sensor activity I see via alarm.com, but I’d like to understand if:
- my device is malfunctioning
- the instructions are inaccurate
- operator error (most likely…)
If the above description isn’t clear, I can probably post a video, but I’m hoping someone familiar with this device might be able to explain what I’m seeing.
My device configuration, if it matters:
DIP1 = ON -> low sensitivity
DIP2 = OFF -> low temp fault
DIP3 = OFF -> 60 Hz filter
DIP4 = OFF -> Normal walk test mode
Only Loop 1 has been enrolled to the panel. That is, per supplied instructions, I enrolled the sensor to the panel only by activating the sensor with motion, rather than by using the tamper switch (which is used to enroll loop 2/3).
I installed the supplied Animal Immune lens, and I also installed the supplied look down mask.
Thanks!
Chris
