Programming a Qolsys IQ 4 Panel. Have 2 5800COMBO detectors.
The device only reports an Smoke alarm to the panel when programmed to Loop 1 and a CO alarm when programmed to Loop 3 (using the correct addresses of course). In both cases, when doing a test of the device, once the alarm activates, I disarm the system to clear the alarm, but the sensor remains in the active list of devices in alarm. Kind of looks like it is latching but I don’t see an additional way to “reset” the device.
What’s the proper programming configuration for this device to the panel?
I had read (still trying to find where again-I had written it into my notes) that the smoke must be on Loop 2 and the CO must be on Loop 1, but neither report alarms on those settings.
The sheet referenced previously is the most recent information for both IQ Panel 2 and 4, they have not released anything newer.
I spoke with Qolsys representatives today and was told its specifically not compatible. I have reached out to get conformation and I will follow up as soon as I hear back.
Any update on this? I am about to buy some smoke detectors and it would be nice to have CO built in there as well. Is there anything compatible with the IQ4 that does both?
Thanks!
