Found some hidden settings of tstat… not sure what they are for though, even though I think one may be the elusive “reset”
Edit: definitely the RESET
When off, Hold up/down arrow, mode to select.
Zwave/firmware versions?:
When off, hold up, mode to select.
Normal Mode:
Heat pump Mode (haven’t found way yet to change staging):
These are described in the manual if I recall.
I don’t think you can reach the full suite of features on the tstat though, sadly.
Definitely for the mode, not sure about the reset option. And the 1.20 and 1.10 is definitely the firmware/zwave version.
In any event I reset tstat, and cleared all stored data. So maybe this will resolve my scheduling issues.
I found the reset feature last week when I was monkeying around with my battery vs ac reporting issues. The other stuff I saw but hadn’t a clue what it was telling me so I ignored it
I’ll check the manual again but don’t recall seeing anything that technical…
Not the alarm.com T2000 manual, but the real manufacturer’s manual for B36-T10 tstat. I uploaded the PDF in one of these T2000 threads
Apparently Building 36 splintered off Radio Thermostat.
Ah OK, I have that one saved here somewhere too, the one with the green instead of orange cover, but never looked that deep into it.
…and then alarm.com bought them (2012) ![]()
