Help setting up new sensor
Hello all,
I am having trouble with a DW10E that does not seem to have been added properly. This is an exterior door and my settings are in the attached screenshots. The system thinks the sensor is not ready so I cannot arm however I can get it to trigger in system tests. I am assuming this is user error but I can’t figure it out, any help would be appreciated. Thank you!
Looks like this would be the Loop number. The internal magnetic reed switch in the sensor uses Loop 2.
Loop 1 is for the wired input. Change the Loop to 2 and test again.
Most other types of 2GIG sensors use Loop 1 as the standard sensor loop, it just depends on the model.
Thanks Jason for the suggestion and the loop explanation. I changed it to loop 2 and it worked right away
