I’m doing a new build and plan to have all sensors hardwired and run to hardwire 16F’s.
My current house is setup this way and I needed a total of 3 Hardwire 16 to support all of the sensors. The new build will have about the same amount of sensors or a little more.
A couple of questions…
1. What is the difference between hardwire 16 & 16F?
Some of the things I picked up was…
a. It now sends a wireless signal to the IQ2 panel to set off the alarm instead of needing a hardwire run to the panel.
b. It supports smoke detectors.
What are the other changes/updates?
2. Does the Hardwire 16F Large Enclosure include 2 hardwire 16F’s inside?
3. It looks like the new hotness is the Qolsys PowerG PG9WLSHW8. Currently the IQ2 only supports 2 of these with a planned firmware update in the future to support more. Do we know when that update will happen and how many it will support in total?
4. Last I checked there were no combo smoke/carbon monoxide detectors. Does this mean I have to have 2 separate in each area and both will need to be wired to the hardwire translator? Nest Protect wont integrate?
5. 2-Wire smoke is better choice than 4-wire smoke?
6. Is there any known or rumored new tech on the horizon coming by end of 2021 (Example: IQ3 panel, Hardwire 16F Plus, Etc.) where I should hold off buying equipment now?
7. I chose doing hardwire 16 so everything is essentially hardwired, no batteries need replacing ever, all in a clean home run. Do you advise a different whole home setup?
Thanks for all the help!
