Install or replace a failed drive in the 20XXP and 21XXP series CSVRs
CSVR units are shipped with WD Purple hard drives, SATA 6 Gb/s (WD64PURZ).
Important: Install the serial advanced technology attachment (SATA) hard drives before enrolling the device. The CSVR supports most standard SATA hard drives. SATA hard drives are user-supplied.
To use a drive with a CSVR, it must be unformatted. Hard drives with preexisting formatting or data may result in unexpected behavior during recording or software updates. If you are not familiar with the process of erasing formatting or partitioning information, we recommend purchasing a new, unformatted drive instead.
To install new hard drives
3. Remove the top cover of the chassis.
4. Connect the SATA power cable and SATA data cables to the main board.
5. Connect the SATA power cable and SATA data cables to the new hard drives. When installing hard drives, the label sides should be facing up.
6. Align the bottom of the hard drives along the bottom of the enclosure. The connector sides should be facing towards the center of the chassis.
7. Using a screwdriver, install screws from the bottom of the chassis to secure the hard drives in place.
8. Below is an example image of the inside of the enclosure after installation of the hard drives. The label side of the hard drives should be facing up.
9. Slide the top cover back onto the chassis. Using a screwdriver, re-install screws onto the sides and back of the chassis.
10. Enroll the device.
To replace failed hard drives
4. Using a screwdriver, remove the screws from the bottom of the chassis to loosen the hard drives.
5. Disconnect the SATA power cables and SATA data cables from the failed hard drives. Then, remove the failed hard drives.
6. Connect SATA power cable and SATA data cables to the new hard drives. When installing hard drives, the label sides should be facing up.
7. Align the bottom of the hard drives along the bottom of the enclosure. The connector sides should be facing towards the center of the chassis.
8. Using a screwdriver, install screws from the bottom of the chassis to secure the hard drives in place.
9. Below is an example image of the inside of the enclosure after installation of the hard drives. The label side of the hard drives should be facing up.
10. Slide the top cover back onto the chassis. Using a screwdriver, re-install screws onto the sides and back of the chassis.
11. Plug in and power on the the CSVR.
12. Once the CSVR device is back online, the drives must be discovered by the dealer.
