Go Bridge setup
Recently tried to install Go Bridge. Everything connected, all firmware up to date, but Go Bridge test failed. No cellular or landline service. Setup was done step by step. Why did test fail? Thanks.
You’re trying to get this setup without a cell module? Correct?
Both lights on the front of the Go Bridge green?
Do you currently have an Alarm.com account? Keep in mind if you intend on using Alarm.com, you will not be able to use the Go!Bridge only.
All Alarm.com accounts require a cell module for activation.
The Go!Bridge test also requires a backend service to be in place. If you test without an account (ADC or otherwise) I believe it will always fail as there is no server response.
