I have a Smartthings V3 hub set as primary controller and my 2GIG panel is the secondary. I have a lot of lights that function flawlessly, however I just recently ran into a problem when I added several z-wave water leak sensors. The sensors, after about 24 hours, migrated from the Smartthings to the 2GIG, and now show up as an unknown device with a yellow error.
The actual error on each of the failed nodes is the same, “routing slave, inclusion incomplete! by: unknown manufacturer.” The screen also prompts me to “Press failed device’s button to remove it.” Which I’ve done, but it also removes the water leak sensor from Smartthings.
Is there a way to hide it, or bypass it, or even remove it without causing it to also be deleted from Smartthings?
Thanks.
