I am planning to install the garage sensor shown in this thread https://suretyhome.com/forums/topic/garage-solution-to-replace-re-tilt-sensors/ using an RE201 and this switch https://www.amazon.com/gp/product/B0006M1I1W/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1. However, I’m having some trouble visualizing where the pieces will go. Does anyone have any other pictures of their install, perhaps not as close-up as in the original thread? Thanks!
I do not have a further back image of an installation of that particular sensor, but the following image is similar to how the sensor in the post you linked is set up:
You would just connect the wire leads of the Overhead door contact to the RE201 inputs. The RE201 would be mounted to the wall.
For details on setup, see the following:
Thank you Jason! That picture does help.
