The big question would be do you have the Sky panel, or the Go!Control panel? One does not use Alarm.com. The other does. We would be unable to give advice on compatibility with non Alarm.com systems.
You would need to verify with your service provider any limitations on your service plan, but if your system is using Alarm.com as the remote service platform, yes, Liftmaster MyQ equipment integration is possible.
Gotcha. I would think no limitations but could be wrong. I’ve got their top package and was able to integrate a Resolution Products driveway sensor and GE z-wave light switches in the entire lower level of the house.
Was looking for best solution for integrating an opener into the environment.
The MyQ service is integrated directly with the Alarm.com back-end, not with the Alarm panel locally (unlike Zwave or Sensors) and needs to be enabled on accounts. If you see a “Garage” section under your Automation (empower) tab in Alarm.com, it is enabled.
Yep, you would be wrong. Been a couple years since I left Vivint… but I think the following still holds true.
Vivint doesnt allow their customers to run the newest firmware, and keeps the gocontrol on 1.9.6 (and usually most customers are running firmware below that), which is as of right now, four versions out of date. Current firmware is 1.13.
For Vivint users, there are no second generation PIR motions with built in infrared cameras (Image Sensors), No alarm.com GEO location services, no wireless broadband internet bridge capability, no Alarm.com wellness, no energy metering, etc.
By default, Vivint users, are not even offered alarm.com Gold plans.
psinsyd, It’s definitely better having it in the alarm.com app vs the chamberlain app. For one you don’t need to give the rest of your family new logins, and two the rules you can setup for automatically closing the garage door based on your arm state are great.
Totally agree, Donato. I’ll continue looking at my options, and also may look at moving away from Vivint to see if that opens up the door to this as well as other options as well.
