Hello I currently have my opener connected to Alarm.com. I am having my garage door opener replaced with a new model opener that uses MyQ technology as well. If they wire in my 888LM I currently have to the new opener, will I have to re learn the setup or should it continue to work?
Ok I had the new opener installed that has the integrated wifi and I was not able to use the old MYQ remote with the new opener. I now have to setup the new remote. Can I remove the old MYQ account from my river account or do you have to do it. Also is there a link you can send for setup, it has been awhile…thanks
Yes , only the dealer can remove MyQ gateways from the account. Commands have been sent to remove the old gateway at this time Please allow 5-10 minutes for those commands to process.
In order to add the new Gateway, please login to your Alarm.com account, navigate to Settings > Devices > Automation Devices > Add Liftmaster.
