tyler
(Tyler)
February 6, 2024, 3:00pm
21
Thank you for that information.
At this point either the unit itself is experiencing failure and should be replaced, or there is an undocumented compatibility issue with the overhead and the Linear Controller.
I’m not showing an order through Surety for a Linear Controller. You may need to reach out to the vendor for warranty replacement. You may need the serial number from the side of the box, or on the underneath side of the unit itself.
I will return this and buy a new one
The new unit did not work.
I am going to buy a new garage door opener. Which are compatible with alarm.com and surety?
Thanks!
tyler
(Tyler)
March 4, 2024, 4:49pm
24
Garage automation control through Alarm.com can be found through:
Linear brand Z-Wave GD00Z-X
LiftMaster Chamberlain myQ (additional fee applies)
LiftMaster/Chamberlain Wi-Fi Garage Door Opener
Myq Garage Wi-Fi Hub/Door Sensor (821LM)
MyQ Control Panel and Internet Gateway (888LM/828LM)
Aladdin Connect by Genie and Overhead Door by OHD Anywhere
A list of compatible hardware from Alarm.com can be found here:
More information on devices and installation can be found here
Smart control of your garage can add additional access and awareness to your property and there are a few different ways to set up home automation control of your garage door with Alarm.com.
With Garage Door Integration you can:
Check to see if garage doors are closed
Remotely open and close garage doors
Automatically have garage doors close when the system is armed
Receive alerts and actionable notifications if garage doors are left open
Alarm.com-Compatible Garage Door Equipment
Ecolink …
If I want the LiftMaster/Chamberlain Wi-Fi Garage Door Opener then what additional fees do I need to add to my plan?
tyler
(Tyler)
March 6, 2024, 1:51pm
26
Use of myQ devices requires the Surety Home or Surety Complete service plan and the Liftmaster/Chamberlain MyQ ($1 /mo) add-on.
Changes to your service plan are made through the System Manager feature of your Surety account. This process can be done at anytime.
