I have a Front point system from 2014. Ge Simon xt Control Panel. I would like to leave them and use my sensors. What control panel would be compatible with my existing recessed sensors and smokes.
Doors UTC Fire and security Part# TX-1510-01-1
Smokes tx-6010-0101
Both parts seem to be ge part numbers
Thanks
Ed
suretyDIY is an Alarm.com service provider, and the Simon XT is a compatible panel. (the dealer you mention also uses Alarm.com.)
Since the communication modules are shared between the two, the steps to get started with suretyDIY are the same between the XT and XTi. This page goes over how to get started with an existing Simon panel.
If you have already determined you want to replace the alarm panel with a newer panel, the Qolsys IQ Panel 2 also uses a GE 319.5mhz radio and would be compatible with the same sensors out of the box.
