Force Bypass not working from mobile app
Does my VISTA 20-P need to be programmed to allow Force Bypass? When I try to arm my system AWAY from the mobile app when a sensor is open, I select Force Bypass but the system won’t arm (the keypad just displays the faulted zone). When all the sensors are “closed” and there is no need to use Force Bypass, the system arms but in the STAY configuration even though I chose AWAY.
Nevermind, I was able to find the answer in the programming manual (thank you ChatGPT). Fields 23 and 84 needed to be programmed (no Auto Stay and Enable Forced Bypass).
