I have an IQ Panel 4 installed with a variety of window, door, shock and motion sensors. No issues.
I went to install a couple of Flood Sensors and 30-60 minutes after install I got a false water warning. I first went with the supervised (38) and then to (25 - unsupervised) mode to avoid getting a call from Surety [very timely call by the way].
The first flood alarm set I installed were Ecolink TX-E611
The second set I installed were alula Resolution RE118
Both installed easily, but had the same false warnings.
The RE118 is not actually found on the supported sensors list. The TX-E611 is though, can we test that one?
I’d like to see the programming for it and can you confirm the length of time before a false trigger occurs? Does it always happen after the same length of time?
Items can be returned within 30 days of purchase only if equipment is still in full working order with no visible damage or wear and tear and is returned complete, in the undamaged original packaging.
