Is there a programming configuration that would allow me to achieve the following outcome?:
I have water sensors near possible problem sources such as my hot water tanks, well expansion tank, and washing machine. I also have a float switch above my sump pump that if failed, will be triggered as water rises above where it should be.
What I’d like is to have is my panel alarm, alerts on my phone, and a call from the Central Monitoring Station to tell me the alarm is happening/sensors have been triggered; BUT, I DO NOT want any police, fire, EMS, or other services dispatched.
That is the normal process for environmental alarms such as flood or low temperature alarms. No dispatch would occur, operators would first call the site if a premise number is available then dial contacts.
