Earlier today one of my IQ Smokes started beeping for a low battery, so I removed it from the mount, removed the batteries, and left it until this evening when I could get batteries. I insert the new batteries, the panel chimes for the tamper since it was not mounted. About 30 seconds later when I was about to put it back into the mount the panel triggers full siren. I race to the panel, clear it with my code and silence the alarm and it just instantly repeats.
What is the logic behind this? The logs just show (inverse order, as that is how Alarm.com gives them):
Second floor master bedroom smoke - Fire Sensor Trouble
Second floor master bedroom smoke - Tamper
Second floor master bedroom smoke - Pending Alarm (Awaiting Panel's Programmed Delay)
House Disarmed by ME
Second floor master bedroom smoke - End of Fire Sensor Trouble
Second floor master bedroom smoke - End of Tamper
What would possibly explain this? What about these events would require a full siren event from the panel?
I am rather frustrated with the IQ Smoke. For the price point of a “monitored” sensor I would expect it to tell me something about the battery before it’s dead enough to start beeping. I would get better battery monitoring from almost any lower cost connected smoke alarm that isn’t tied to my panel. I have another IQ Smoke that just randomly false alarms for no findable cause that I have just taken the batteries out of and left in a box since weeks since shortly after purchase.
That “Pending alarm” event means that the sensor sent a fire alarm signal to the panel. Disarming the panel while the sensor is still actively reporting an alarm will typically result in a subsequent alarm event at the panel, this is expected. Disarm does not dismiss future triggers of that sensor.
When working on sensors, especially fire and CO detectors, it is recommended to place the account on test mode in our system manager to avoid accidental dispatch. Accidental activation is possible depending on the sensor, where the sensor is placed, accidentally hitting the test button, etc.
The sensor will report a resolution to the trouble condition/tamper when returned to its mount.
A low battery event will coincide with the sensor itself beeping and flashing its LED to indicate the condition. This is so even if it is not connected to a panel, the sensor warns the user of a low battery. This is expected and I believe a requirement by fire code.
Common causes of false alarms are described in the link below. Where was this one installed?
How many alarms occurred, and can you confirm the rough date when this was active on the system?
