We have an existing sump pump controller that is used to monitor sump level and alternate the two pumps in the sump basin. The controller also has a no/nc relay to signal pump failure, high level alarm, power outage/etc to alarm system.
Is there an easy way to send the no/nc signal to IQ 2 plus panel fo awareness of sump issues?
Yes, if you have a NC output you can connect that to a sensor with a wired input. You can program that sensor in as a group 25 sensor which can be used for Alarm.com notifications.
An example sensor would be the IQ Extended door/window if you have the standard 319.5 mhz version of the IQ panel.
I have a sump pump controller that supports alarm output. It’s a RJ11 jack and the middle two wires control the signal. Normally open, but closed when an alarm happens such as failed sump pump.
I could go with the sensor described above, but I’m thinking that there are now newer sensors such as the PowerG+ PGP9945E.
If I went with the latest sensor that supports this capability on the IQ4, is that the PGP9945E? any other PowerG options?
