Home has two doors where the exit/entrance path has you going through both doors. Both doors are both configured as entry/exit zone type.
When exiting after arming and Auto Exit Time Extension is enabled, is the additional time added when the second zone is faulted going to be the time defined for exit delay, or is it always some other fixed time?
When entering to disarm, what happens to the entry delay time when the second zone is faulted?
When the Auto Exit Time Extension feature is enabled on an IQ Panel 4 and a second entry/exit zone is opened during the exit delay, 60 seconds will be added to the exit delay timer.
This does not change the behavior with the entry delay. If two entry/exit zones are opened during the entry delay, it will continue to count down based on when the first zone was opened. If the entry delay expires without the system being disarmed, an alarm will be triggered, and the system will report an alarm from both zones.
