how do i lengthen the entry delay?
I have a firmware version: v.1.9.6
build: 9766
It looks like you are referring to a 2GIG Panel. To edit the entry delay timers on a 2GIG Panel:
Enter System Configuration using your installer code. Press “Go To” 06. Q6 controls the delay timer for Entry Delay 1. Q7 controls Entry Delay 2.
You’ll want to edit them based on which sensors are programmed as those zone types. In many cases, Entry Delay 2 is unused.
You can lengthen the delay up to 240 seconds.
