If I arm my IQ2 “stay”, will there still be an entry delay as when I arm away?
Depends on your settings.
You can toggle exit delay on and off. Settings > Advanced Settings > Installation > Security and Arming > Arm Stay - No Delay.
No Entry Delay is always an option at the time of arming and can be applied either when arming via the panel or via the app.
Picky backing off of this… Can I set Delay Entries for Arm Stay differently for each sensor? i.e. Arm Stay > Backdoor > No Entry Delay; Arm Stay > Front Door > Entry Delay.
Also, can I set different delay entry times for Arm Stay versus Arm Away?
It is not possible to apply no entry delay to only a selection of entry exit doors. The no entry delay option when arming applies to all zones.
You can set a different entry delay based on sensor, but not based on arming state. If you choose the Long Entry Delay sensor group when programming the sensor it will use the Long entry delay timer when that zone opens.
Thank you for that, wish there was more customizability
