Ecolink GDZW7-LR / GDZW7-ECO Compatible Garage Door List
Below is the compatibility list for the GDZW7-LR (Ecolink GDZW7-ECO) module, based on our internal tech notes. This is a general guideline and not exhaustive — please check specific model notes before installation.
Brand Model Compatible Notes
Chamberlain with/without Wi-Fi logo Optional Yes if Security+; if Security+2.0 and made after MD2018, may or may not work
Liftmaster with/without Wi-Fi logo Optional Yes if Security+; if Security+2.0 and made after MD2018, may or may not work
Clicker with/without Wi-Fi logo Optional Owned by Chamberlain, same Security+/2.0 rule applies
Craftsman with/without Wi-Fi logo Optional Owned by Chamberlain, same Security+/2.0 rule applies
Raynor with/without Wi-Fi logo Optional Owned by Chamberlain, same Security+/2.0 rule applies
Genie Alliance (1954-1983) Unknown Most likely yes; may need relay output timing adjustment
Genie Series 1 (1983-1995) Yes
Genie Series 2 (1995-Today) Yes
Genie Series 3 (2010-2012) Yes Certain serial/model combos need Genie 38013R adapter (see TB2023-08-31)
Genie BeltLift Yes
Genie Blue Max Yes See TB2023-08-31 Series III note
Genie ChainGlide Yes
Genie ChainLift Yes
Genie ChainMax Yes See TB2023-08-31 Series III note
Genie DirectLift Yes
Genie DirectLift Plus Yes
Genie Excelerator Yes
Genie Gpower Yes
Genie IntelliG Yes
Genie Medallion Series (1990s) Unknown Most likely yes; may need relay timing adjustment
Genie Norleco (1954-1983) Unknown Most likely yes; may need relay timing adjustment
Genie PowerLift Yes
Genie PowerLift 900 Yes See TB2023-08-31 Series III note
Genie PowerLift Excelerator Yes
Genie PowerMax Yes See TB2023-08-31 Series III note
Genie ProMax Stealth Yes See TB2023-08-31 Series III note
Genie QuietLift Yes
Genie ReliaG Yes
Genie ScrewDrive Series H Yes
Genie ScrewDrive Series IC Yes
Genie ScrewDrive Series IS Yes
Genie ScrewDrive Series ISL Yes
Genie SilentMax Yes See TB2023-08-31 Series III note
Genie Stealth Yes
Genie TrilloG Yes See TB2023-08-31 Series III note
Overhead Door Destiny Yes See TB2023-09-01
Overhead Door Infinity Yes See TB2023-09-01
Overhead Door Legacy Yes See TB2023-09-01
Overhead Door Odyssey Yes See TB2023-09-01
Overhead Door Overdrive Yes Relabeled Genie operator
Overhead Door Phantom Yes Relabeled Genie operator
Overhead Door Python Yes Relabeled Genie operator
Overhead Door Signature Yes Relabeled Genie operator
Overhead Door SilentMax Optional See TB2023-08-31 Series III note
Overhead Door Standard Yes
Linear - Yes
Wayne Dalton ClassicDrive (1990s) Unknown May need relay timing adjustment; 30V monitored connection may not work with relay trigger
Wayne Dalton Quantum (1990s) Unknown May need relay timing adjustment; 30V monitored connection may not work with relay trigger
Wayne Dalton DoorMaster Yes
Wayne Dalton iDrive Yes
Wayne Dalton ProDrive Yes
Access Master - Yes
BuildMark - Yes
Do-It - Yes
Master Mechanic - Yes
AssureLink - Optional Owned by Chamberlain, same Security+/2.0 rule applies
True Value - Yes
Garage Access - Yes
Merlin - Optional Owned by Chamberlain, same Security+/2.0 rule applies
Sommer Direct Drive Yes
Sommer evo+ No Wi-Fi only, no external trigger option currently
Sommer Guardian Core Series Yes
Sommer Pro Series Yes
Sommer Xtreme Garage Yes
Sommer Performax Yes
Marantec Synergy Series Optional Requires optional Marantec XB03 terminal expansion block
Marantec M Series Yes
Marantec Q Series Yes
Marantec Ex Series Yes
Marantec AZ Series Yes
Marantec Mac-Lift Series Yes
Marantec STA Series No
Marantec MDF Series No
Marantec MTZ Series No
Marantec VTA Series No
Marantec RV Series Yes
