I removed the outdoor siren from my Impassa and deleted it from programming as well as turning off temperature display in programming on main panel. I have as aux panel WTK5504 that also displayed the temp. The last recorded temp is still displayed on the 5504. How do I remove it?
Never mind. I figured it out. You have to remove power, both AC & Batt from keypad. This will cause it to clear. Just plug both sources back in and the temp display is gone.
Good! I haven’t seen that happen before. I was going to suggest power cycling the keypad but to be honest it was just a guess.
