DSC PowerSeries Pro
With the Power Series Pro, I understand ADC signalling would pass through the TL9080 communicator, but I would like to use the onboard ethernet to allow signalling direct to the monitoring center and use the ADC communicator as backup. Would that be possible with Surety?
No, you wouldn’t be able to use the onboard Ethernet port to signal directly to the monitoring center; however, the TL880, which is the Alarm.com communicator needed for PowerSeries Pro, has dual-path communication built in. You can run an Ethernet cable to the communicator to use both broadband internet and cellular simultaneously for signaling.
