I have a problem with a DSC PowerSeries (PC1832) system which I haven’t seen described anywhere, and I’m wondering if others have dealt with this.
Short question: is it possible to use wireless zones in the range claimed by a PC5108 zone expander? I haven’t seen any documentation that says it’s not, but it’s causing me problems (see below).
Longer description:
This house had an existing wired alarm system but a few of the zones were not working (broken wiring) so I replaced those zones with wired sensors.
The PC1832 has 8 built-in zones, and can support a total of 32 zones either as wireless zones via an RF5132 or as wired zones with additional zone expanders (PC5108). I have one PC5108 jumpered to be zones 9-16. That leaves me with zones 1-8 as the builtin wired zones on the PC1832, zones 9-16 as additional wired zones via the PC5108, and zones 17-32 as wireless only.
In this configuration, all the wired zones (1-8 on the builtin circuit board and 9-16 on the PC5108) work fine, and all the wired zones 17-32 work fine. But the zones that used to be wired as 6 and 11 have broken wiring, and I replaced those with wired sensors. I set the wireless/AML zone attribute (option 8) for those zones. Zone 6 (which could have been a builtin wired zone but is now configured as a wireless zone) works fine. Zone 11 (which could have been a builtin wired zone but is now configured as a wireless zone) comes up as “zone fault” every time the panel exits installer mode; after that point, opening and closing the affected contact sensor will clear the zone fault (and the zone status is reported correctly), but entering/exiting installer mode brings back the zone fault again.
I tried a few things (deleted zone 11 and added it back, moved it to zone 15 which was unused, completely defaulted and redid the RF5132 programming, replaced the sensor used for zone 11) and none of that helped. Then I temporarily moved the zone 11 programming to zone 22 (outside the range used by the PC5108) and it worked fine. Meanwhile, zone 6 (also a wireless sensor overlapping the wired zones) works fine.
At this point the only difference I see is that zones 11 and 15 are overlapping the range used by the PC5108, and might be “claimed” by the PC5108 and cannot be used by wireless zones? I haven’t found any documentation to that effect, the panel will let me program it that way, DLS programming software lets me program it that way (and DLS generally has a bunch of warnings about programming errors, and it doesn’t consider this one). The zone status is even reflected correctly. But the recurring zone fault makes it a deal-breaker.
Has anyone seen or dealt with this, know how to fix it, or know for sure that it it doesn’t work and I need to renumber my zones to avoid this case (any wireless zones overlapping the range claimed by a PC5108)?
