I have searched and can’t find anything. Does DSC make a corner mount bracket that allows for adjusting the angle of the PG9984? If not is there an aftermarket mount that will work. I want to mount mine about 10 feet high but want to give it a downward angle.
The DSC PGBRACKET-2 is what you are looking for.
Looks like it can be found here.
Thank you Jason for that. I did see that and just wanted to confirm. Question, is there much of a difference in performance on the PG9984 vs the PG9914? I am planning on placing it about 9 feet high using the bracket to angle down a little
Those models have different detection methods. The PG9984 helps filter more false alarms using dual PIR and Microwave detection.
Thank you Jason.
