Does anyone know if there’s a driveway sensor that can be incorporated into my system? I have the IQ Panel 2.
Thanks!
Thanks!
While we do not carry a driveway sensor, the Resolution Products RE104 is a Driveway sensor that should be compatible with the IQ Panel 2. Instructions and specifications for the sensor can be found here.
Thank you for the quick response. I’m not sure that would work because it has to be within “wireless” range. The spot I’d have to mount to is about 150 feet away from my panel.
You could use a repeater mounted further from the panel but closer to the Driveway sensor. Something like the RE524X would work.
Thanks. I didn’t think I could use a repeater with the IQ2. I’ll check this out.
You would just set it to GE for both knobs. Note that the repeater wont repeat the signals of S-Line sensors, just 319.5MHz
