My driveway sensor will go offline every once in awhile. I moved it closer, but still happens. Currently it is about 250ft from the main panel. Any suggestions are appreciated.
It says: Loss of Sensor Supervision on message
Driveway sensors typically account for a longer range, but 250 feet may still be pushing it depending on the environment and construction the signal must go through.
What model of driveway sensor do you use?
It’s the resolution products one
