I connected a simple push button switch to a QS1137-840 sensor to function as a doorbell. It’s programmed as group 25; type: doorbell; name “Doorbell”; “Activity Monitoring” is active.
After saving it, I pressed the button and the panel chimed as expected. But, it wouldn’t work after that. If I delete the sensor and renter it, it works… once.
I checked the sensor status. before pressing the button it shows “Active”. After pressing the button it shows “Activated” bur never returns to “Active”.
If I bring the sensor magnet next to the sensor and then move it away the panel chimes. Its as if the wired terminals are not working.
Can’t figure out what’s gone wrong. Any suggestions?
