Is there a way to disable the countdown when disarming alarm when it is in a stay, no exit delay? Somtimes when my son or wife go to work early, they tap on the screen to disarm the alarm and either they take too long or enter the code incorrectly and the alarm goes off. What is the purpose of the countdown if everyone is home?
Unfortunately there is no way to disable the count down and as long they don’t open a door until they disarm the system even though u tap on screen and it starts beeping it shouldn’t go off it should just go back to arm state only thing I can think of is turn it off on the app or key fob before opening the door
Just to clarify, are you referring to the beeping itself? It sounds like you mean you just want the system to disarm immediately by pressing the disarm button and not having a code entry, is that right?
If so, in general that would defeat one purpose of the alarm system, giving anyone with physical access to it the means to disarm it.
To disarm without a code, you can do so from within the app while logged in or via a keyfob.
