Disable Home screen pin code
Hi. To get to the Home screen, I need to enter a Pin code and then to disable the alarm, I need to re-enter the code. Is there a way to eliminate the Home screen pin code?
Thanks
This can be disabled by logging in as an installer or dealer by using the installer/dealer code on the home screen pin > Settings > Advanced Settings > Installation > Security and Arming > Disable Screen lock
How do I login as an installer or dealer. I can login as the admin but I don’t see an Installation option on the Advanced Settings page.
Thanks
Enter the Installer or Dealer code on the home screen pin code page. If you are currently logged in as admin, swipe down on the main screen and there should be an option to log out or exit user. You can also wait until it times out and the pin code page appears on the home page again.
NVM. The Default Dealer/Installer codes worked so this fixed it. Thanks for the quick help!
