I am setting up some water sensors and am testing them, but am wondering if there is a way to not get the full on alarm siren when they trigger? Right now they are set up as 24-Auxiliary in a 2gig GC3 according to typical instructions.
I would like some audible alert, but don’t want to get confused between an actual burglary and a water leak if I am woken up in the middle of the night by it. Is there a way to change the tone?
There is no alternate cadence for the alarm siren, it cannot be changed. You can change the reporting type of the sensor in questions to “23 - No Response Type” (Note that this would not be forwarded to the Central Station). You would then set up notifications through Alarm.com to be notified when the sensor is activated. Locally it would only chime per chosen chime options for that sensor.
