Im planning out my new system and trying to figure out how to secure my detached garage. Here’s my thoughts.
I want to put in motion and a window sensor in my detached garage. My concern is that my wife will pull into the garage w her car before turning off the alarm, triggering an alarm every time.
If I incorporate a garage door opener into ADC, is there a way to create a rule saying that if garage door is opened, deactivate sensors in the garage? I’m trying to figure out the easiest way to secure the garage
No, there is not a way to do that. The system would need to be disarmed or on Arm Stay mode in order for the motion to not trigger an alarm.
With MyQ or Linear garage automation, you can set up rules to turn on/off light or begin camera recording based on the garage’s open/close status.
You can also close the garage based on arming the panel or when disarming the panel, open the garage.
A scene that disarms the panel and opens the garage with the same action is an option, but it could potentially still cause a false alarm if the door opens before the disarm command reaches the panel. It should be possible with the panel connected to Dual Path for broadband commands, but even then command latency will likely cause an issue at times.
You may want to consider an Entry/Exit sensor on the door and a shock sensor on the window instead of the motion in that case.
One PG9312 for the window + wired shock in case of glass breaking. The shock is optional.
One PG9312 for the door, which would use a wired overhead garage contact. A roll up door should use a wired contact designed for installation on the roll up overhead door.
The PG9312 has a wired input inside it to make use of wired contacts.
I think I see. So the metal contact thing on amazon would get wired into the pg312? I didnt realize it would get wired to the sensor. Judge from the video on the DSC website, it looks pretty straight forward.
Also, why the outdoor sensor relative to a different powerG window/door sensor.
Yes. The overhead contact would be wired into the wire input terminals inside the PG9312. The PG9312 would then act as the transmitter.
I recommend using the outdoor sensor model due to the detached garage location. If it is not a temperature and humidity controlled environment, go with the outdoor sensor to avoid future issues.
