Amazing to find this resource and the knowledge within…thanks in advance for the help!
I have an old ADT system and I’m looking at coming over to Surety with a Qolsys IQ Panel 4 but have questions thinking through how it will all work…
Old system:
ADT Safewatch 3000 (Vista 20p WA3001-5.5 chip, 2008, rev 5.5). Owned, cancelled monitoring, and have the master and installer codes
Wireless: 5800 series sensors (door/window, motion, smoke)
Wired: keypad, wireless receiver, siren, phone landline, cellular relay
New:
- Intending to replace the keypad with Qolsys IQ Panel 4 (345Mhz to work with the 5800 series sensors)
Questions / Issues:
Redundant hardware to remove?
My understanding is the IQ Panel 4 has cellular capability, wifi, and wireless receiver for sensors…Does it completely replace the functionality of the Vista 20p panel? I’m trying to figure out what hardware can be removed or needs to stay.
May I disconnect and remove the old wireless receiver and cellular relay devices?
Is there any need for the phone landline anymore or does the monitoring communication happen through wifi / cellular?
Would disconnecting the wired landline from the Vista 20p panel cut it off to the house (is it relayed)?
Is the Vista20p panel itself needed anymore with a Qolsys IQ Panel 4 installed?
Power
It appears the old system was powered by a 16.5V transformer to the Vista20p panel (terminals 1&2) and that the old keypad received power relayed from terminal 4&5 on the panel. Does that sound right?
In this setup will I need to add separate power wiring for the new Qolsys IQ 4? The old keypad seems to be relayed 12V power from the Vista20p and the Qolsys comes with a 7V transformer.
Qolsys communication to Vista20p
The old keypad seems to communicate with the Vista20p via hardwiring to the data terminals 6&7. Does that sound correct?
May that wiring be removed in my new scheme and how does the Qolsys communicate with the Vista20p?
