Thanks for your patience while we looked into this!
Unfortunately, Smart Arming is only available on systems with a single partition, so it can’t be enabled while your garage is set up as its own partition.
There’s no issue having two systems in one location. You would just delete the garage sensors from your current system and add them to the new one. Then disable multiple partition support on your current panel so it goes back to a single partition. After that, Smart Arming will be available.
If you’d rather keep everything on one system, you could also add Automatic Arming Schedules ($4/month). It lets you set schedules that arm each partition automatically at set times, and it can re-arm a partition if no activity is detected after it’s disarmed. Smart Arming isn’t available while this add-on is active. It works on a fixed schedule so its different than Smart Arming but its close. You can find more details here:
If you have any questions, just let us know!
